I need a confirm answer for this ..searched the forum but all are just confusing
Can we use the 4GB memory (partionioned for video , songs etc) for apps in addition to 2GB so that it totals 6GB for apps??
Solved! Go to Solution.
Thanks for posting and welcome to the forum!
Yes, it's possible to move apps to the "other" part of the internal memory on the Xperia U.
What might be good to know though is that it's not only up to the phone if the app is possible to move, the app itself also needs the support for being able to be moved to another memory after being installed.
What do you think about this forum? Let us know by doing this short survey.
PS I have already seen this thread
http://talk.sonymobile.com/thread/45954 and it creates confusion.
