wel wen i play some song or video on phone theres this cracking sound i tried different songs, but when i switch my phone off and thn try it der s no cracking sound ,,, help me out
Solved! Go to Solution.
Try repairing your phone via SUS/PCC
Please Mark
enlighten me more abt it
OK this is one odd problem so you can repair the phone vua rhe update service
http://www.sonymobile.com/gb/tools/update-service/
Just follow the instructuins.
All your data will be lost but not media .
Please Mark
I have the same problem on gingerbread after i play defender 2! I don't know why it's happening! Does this cracking occur after a while or after opening an app? If it's because of the second one then it's a bug (from the app)
i had done my factory reset and everything seems to be right..
