how to downgrade to gingerbread
SOLVED
vineeth9809
Visitor
Hi all , Iam using sola with ICS. As I didnt find any further support for this model, i want to downgrade this to previous gingerbread. i dont have any warranty, so how can i downgrade? please help..
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
How to manually update, downgrade, root 2012 Xperias
http://talk.sonymobile.com/thread/41609
4 REPLIES 4
florenzgonzales
Contributor
Use a flashtool and manually install gingerbread
Uliwooly
you have 2 options
1) take your phone to a sony repair center
or
2) use flashtool
Uliwooly
ShayKaPow
Visitor
Just follow my guide far simple and easy (link)
