How to enable sony cloud storage
SOLVED
manish_o7
Visitor
Hi,
How do i enable sony cloud storage & from where can i check the space allocated
regards,
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you have to register with Box and also if you don't have the app  you have to download "Box" from the play store
3 REPLIES 3
Uliwooly
manish_o7
Visitor
Hi,
Its currently showing 5 GB storage, how do i claim sonys 50Gb offer
regards,
Uliwooly
once you use your Xperia it should enable 50GB I don't know if the deal is still good but  you can check the website regarding that
