Still Battery Drain after buying another Battery
SOLVED
Not applicable
Hello, i'm going crazy
I don't understand what is happening with my 4 month old XPERIA RAY Thinking_Face !
I've changed the battery with the new one, switch off my phone and full charged it and when i've starded
the phone the state of the battery was 96%. After 5-6 hours with data activated, no GPS, no Wifi, no blutouth
the phones turn off (0%)... Can't believe that's normal Angry_Face !
When i've bought the XPERIA RAY, i've 2 days before my battery goes empty... And now the phone is heater than
before...
Is XPERIA RAY a big s**t like my first ps3 :smileymischief: ? I hope, i'm not true.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
this seems to be an app acting up
repair your phone with SUS and then don't install any app, don't sync anything, don't even open mcafee and/or any other app, let it sit for 1hr and 2hr
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software
%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
12 REPLIES 12
Uliwooly
charge it 100% then use it as you normally would, once it gets to 10% do this
settings -> about phone -> battery use
take screenshots, tap on each item on the list and copy the amount of hours and minutes they were on post them here as well as the screenshots, also tap on the graph and post it here.
Johan
Master
As Uli posted, please upload screenshots of the usage so we can check.
Not applicable
Ok, thanks, have done, take a few time because of my job :smileywink:.
Thanks a lot !!!
Uliwooly
Not applicable
I've already try this and i've just installed wikipedia app since the repair of my XPERIA RAY  with SUS...
In other hands i've try to unplug my SIM and my µSD , no way, same result...:smileycry:
Uliwooly
you might have to send it to Sony's service center
http://www.sonymobile.com/global-en/support/contact-us/
Not applicable
Ok, thanks for your answers ! Smiling_Face_with_Sunglasses
Uliwooly
Anytime
sawan_bhasin
Visitor
Hi Johan,
I am using sony ericsson live with walkman. My cellphone battery immediately drains out when phone reaches to battery level of 40%, earlier it was 30%? (my cellphone immediately turns off after giving a battery warning) What is the problem with my cellphone? What should i do to get it resolved? Is this problem related to my cellphone or battery?
For your details - it's software is up to date (ICS) and its still under warranty.
I believe i would get an instant and reliable response from you because the service center people make fool of customers. And i dont want to get dissatisfied from your product. Hope you will take this matter on priority basis.
Thank You
