ICS Update Issue: Unable to connect phone in MTP mode
SOLVED
deepeshch2k9
Visitor
When I connect my phone to PC in MTP mode it shows 'Internal Storage and SD card connected to PC'
But on my PC it does not show internal storage or SD card connected.
Is anybody else also having this issue????
Also note that when I connect the phone in MSC mode it shows SD card connected to PC...
and the SD card is also shown on PC...
Please SONY fix this problem ASAP.....
1 ACCEPTED SOLUTION
Accepted Solutions
deepeshch2k9
Visitor
hey...
try enabling USB debugging in Settings>Developer Options>Usb Debugging
It will work i guess...
5 REPLIES 5
deepeshch2k9
Visitor
i.e. I am having problem in connecting my phone in MTP mode after the ICS update...
MetalCrackHead
Visitor
Having the same problem... One way around it is going to Settings>Xperia>Connectivity>And checking the "Install PC Companion"
Whenever your phone asks if it should install the software on connecting to the PC tap on yes and your computer will read it.
This is a temp solution I hope Sony gives a better one... I've already reset my phone once after update and it still doesn't connect the normal way
ringoringo
Visitor
My cell phone is also even though i tried lots of times, it still could not connet the computer.
deepeshch2k9
Visitor
Thanx
It worked for me....
But still SONY must give us a permanent solution
deepeshch2k9
Visitor
hey...
