led light change color
SOLVED
szhieloah
Visitor
i used to have red led light when i receive message but i notice suddenly it changed to yellow and would not stop blinking until i open my message. Is this normal?
1 ACCEPTED SOLUTION
Accepted Solutions
Samuel1
Hero
Yes this is normal. However, you can change these notifications by using 3rd party software. I have used Handcent SMS myself and there you can change colour, blink-pattern and much more.
3 REPLIES 3
Samuel1
Hero
szhieloah
Visitor
oh sorry i meant blue led light turned into yellow
murugadasan
Visitor
yes its normal indication. during charging it will change red-orange-green& if message or other notification will be blue- pink or orange it depence
