i used to have red led light when i receive message but i notice suddenly it changed to yellow and would not stop blinking until i open my message. Is this normal?
Solved! Go to Solution.
Yes this is normal. However, you can change these notifications by using 3rd party software. I have used Handcent SMS myself and there you can change colour, blink-pattern and much more.
oh sorry i meant blue led light turned into yellow
yes its normal indication. during charging it will change red-orange-green& if message or other notification will be blue- pink or orange it depence
