Left Touchpad problem
SOLVED
ExMachine
Visitor
Hello I have the following problem, the left touchpad works only up to the right and down. The left side of the left touch pad does not pressure sensitive. Please tell me what to do.
1 ACCEPTED SOLUTION
Accepted Solutions
Samuel1
Hero
Well, to rule out any software issues you should try repairing the software via PC Companion.
If a software repair doesn't solve the issues you should send it in to a service center for repair.
3 REPLIES 3
Samuel1
Hero
ExMachine
Visitor
Thank you for help, you further questions on this issue - can I ask in the same subject?
Samuel1
Hero
Absolutely Slightly_smiling_Face
