lock bootloader
SOLVED
nandhipatiphani
Visitor
lock bootloader
hi friends i want to know after rooting neo v can we again lock the bootloader?
1 ACCEPTED SOLUTION
Accepted Solutions
yuxandyou
Visitor
Isn't the same thing, if you rooted your phone, that doesn't mean that you have unlocked bootloader.
If you root your device and separately unlocked your bootloader, yes there are some tools on xda forum to do that
1 REPLY 1
yuxandyou
Visitor
