What is this?! 1500mAh on sola? (build.prop)
SOLVED
Trubo_XL
Contributor
Just checking around my phone's root directory and I found a file (no root required)...
/system/build.prop
Inside it, it listed all the stuffs about firmware and some sola's feature (and probably manufacturing date, not confirmed yet) etc....
But what really weird is I came across this...
# system props for Battery test in Service menu
ro.semc.batt.capacity=1500
ro.semc.batt.test.z_threshold=50
ro.semc.batt.test.min_level=70
WTF do you mean by 1500 battery capacity?! All the sites stated that sola only has 1320mAh...
SONY? Are you cheating us again??
Regards,
Trubo
SI: 1264-6670 (battery cover)
Build no: 6.0.B.3.184 (2.3.7)
Country: Malaysia
If that differs among our sola's...
1 ACCEPTED SOLUTION
Accepted Solutions
Johan
Master
I have checked this with concerned developers and it's a human mistake. Unfortunately the ro.semc.batt.capacity numbers in the build prop are wrong. This does however not affect the phone in any way.
4 REPLIES 4
Trubo_XL
Contributor
Oh yeah, just in case you don't know how-to open the build.prop file...
See here: http://forum.xda-developers.com/showthread.php?t=1948558
...and see this for more details...
http://forum.xda-developers.com/showthread.php?t=1587008
Sony... I'm still waiting for your explanation here...
Regards,
Trubo
Message was edited by: Trubo_XL
Not applicable
Hmm, very strange, my build.prop file also shows 1500 value. Also I'm on ics latest build and different region
Johan
Master
Trubo_XL
Contributor
Oh, that's unexpected... (for SONY's high tech??)
So, my phone still detects the phone's battery capacity as 1320mAh then, huh?
Regards,
Trubo
