I charging my phone in on mode .. then i off it while charging to make it fast full charge .. But , whenever i try to on then it doesnt show any battery bar charging n doesnt show any response .. my phone stuck with red led and cannot on its back
. What should i do ?
Solved! Go to Solution.
try to charge your phone using the wall mount chrager, leave it a few hours , see it if boots up
try repairing it with http://www.sonymobile.com/global-en/tools/update-service/
unfortunately this would erase your phone's data.
You can chrage your phone even turned on, there is no big difference/
Doesnt have another way without erase all the data in my phone ?
Btw , i will try your method if my phone doesnt show any response in 1hours ..
Suddenly on after unplugged charger ==! .. Finally my nervous was gone awayyyyy~ and thanks noramlb :smileygrin:
lol :smileygrin:. I suggest you perform a backup, just in case something like that happens again/
trying doing an emergency boot by holding the power key and the volume up key .. may free some some temp files and cache and help resolve
