- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xperia t can't connect to PC via USB cable,
Again and again LED light blinks and connected and disconnected then my cell restarts.
I have changed USB cable, connect to other Laptops and computers but same result.
Neither I have root or flash my Xperia t...... Please help me.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I was having same problem but after i restarted my phone and pc everything works fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i am also facing same problem please tell me the solution
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
After 2 days an various failed attempts I found a simple solution to this issue.
Go into developers mode on your phone
on the L1 this is settings>about phone
tap build number till you enter developer mode
go back to the pevious page and enter developers options
scroll down to networking>select usb configuration
under this option click mtp mode go back to the main page and switch the phone off and on again.
now when you plug the phone in it sould be detected
hth
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
I am struggling since longer time to connect my Sony F5121 (Xperia X) device via USB to my Windows 7 Enterprise or Windows 10 Home laptop.
What did I try?
Installed last version of the Xperia Companion
Developer Settings - USB Debugging
Developer Settings - USB Configuration - MTP
Developer Settings - Revoke USB debugging authorisations
Factory reset and all from the beginning
Restart my Sony device and the laptop
tried different USB ports and cables (basically the cable I used is working for the Sony Xperia III Compact of my wife without any problems).
Random order of the actions above helped once or twice and I could strangely connect and saw all in the windows explorer, so I believe it cannot be a hardware issue.
My patience is running out, I read several posts online, nothing helped to get a stable solution. I just do not want to random actions to get surprisingly the connection. I really like the Sony devices but thinking of changing the brand because this is just inacceptable.
Please help!!!
Thank you and kind regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Any help from Sony? I also have the same problem and nothing works!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My Xperia t can't connect to the PC via USB cable.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Re: hi, my xperia m doesnt connect with my computer by usb
- « Previous
- 1
- 2
- Next »
