Please somebody help me to set up 3G in my sony xperia neo L
SOLVED
ajayknair
Visitor
Hi friends
I m using sony xperia neo L for the last two months with vodafone and since the internet speed is very slow I was trying to set up the 3G in my phone. ,And when I checked the compatibility with vodafone it shows like it doesn't have 3G support .So what is the problem ?Is it the problem with vodafone or sony?
1 ACCEPTED SOLUTION
Accepted Solutions
Apjno1
Visitor
No friend,,, just restart the phone,, n you dont need to setup 3g setting ,, it will automatically set up ,,, you just have to check out the network of 3G in your area... Slightly_smiling_Face
2 REPLIES 2
Apjno1
Visitor
ajayknair
Visitor
Thanks dear friend its working now
