Hi friends
I m using sony xperia neo L for the last two months with vodafone and since the internet speed is very slow I was trying to set up the 3G in my phone. ,And when I checked the compatibility with vodafone it shows like it doesn't have 3G support .So what is the problem ?Is it the problem with vodafone or sony?
Solved! Go to Solution.
No friend,,, just restart the phone,, n you dont need to setup 3g setting ,, it will automatically set up ,,, you just have to check out the network of 3G in your area...
Thanks dear friend its working now
