problem with memorycard at sony Xperia Tipo.
SOLVED
BenjaminRoelfs
Visitor
Hello,
I have a Sony Xperia Tipo for 2 months now and I got out the memory card because I didn't want to destroy the battery by making it lazy.
but it seems afterwards that I did this not knowingly that it should be safely removed.
my question is: must I buy a new memory card or is the mobile Phone ruined?
and If I should buy a new one, what would you recommend?
My Best Regards for the new year!
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
indeed it's quite odd, I'm glad you figured it out, there might be some issues with an app, you could repair your phone with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
6 REPLIES 6
Uliwooly
what do you mean "destroy the battery by making it lazy"?
if you removed the SD card w/o safely removing it, it shouldn't harm your phone, it might harm some pictures, apps, etc on the SD card but not the phone.
BenjaminRoelfs
Visitor
well, if you reload your phone too much it will get lazy. lazy like being unloaded faster.
but my phone doesn't recognize the memory card anymore, so I wander.
Uliwooly
oh I see, no it wont affect the battery. test your SD card on other phones
BenjaminRoelfs
Visitor
ahh good Slightly_smiling_Face
thank you for your help.
I think I figured it out.
on my laptop I have VLC-player and I thought it might also be on anrdoid.
so I have the VLC app on my phone. now it detects he memory card with all content.
but still the phone itself doesn't see it, I think this is rather odd. but it works.
Uliwooly
BenjaminRoelfs
Visitor
ahh superb, thank you!
I'll so the repair. problem solved I think
