Sony Xperia T heats very strong
SOLVED
Domenic
Visitor
Hello. Can anyone help me to find out the problem I have? While using Xperia T in main menu or somewhere else - its cold, but when I open some game or browser (chrome and stock), after 2-3 minutes its starts to heat very strong and drains battery very fast. If I play or surf the internet after 10 minutes it will be very hot from center to right (up) corner. Is it normal for T ? As I had Xperia S,P and other like Neo, Arc, Arc S... even Samsung S3, Nexus 4 and I never had such hot phone as I surf the internet not more than 15 minutes and it drains about 10-15% from battery... Last Android 4.1.2, don't know if it was normal or not at older firmware.. Help please, don't want to sell it...
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
if the game its quite heavy and power demanding the phone will get quite hot that's normal
14 REPLIES 14
Uliwooly
That's normal, there's nothing you can do about it.
Domenic
Visitor
Found the same topic http://talk.sonymobile.com/message/433431#433431
Really I had a lot of mobile phones but this heats very strong i don;t think its normal...
Uliwooly
it is normal, check the temperature with service menu or download an app
Domenic
Visitor
Ok, will test right now, tell me please what is the normal operating temperature ???
Domenic
Visitor
Hello again. I tried to download a lot of apps to my phone (processor info, tests and etc.) no one show a processor temperature and I found a service menu at my phone by special code *#*#numbers#*#* even this menu does not show such kind of information... Question is unresolved =( Maybe I should try to downgrate the firmware ? if it's possible... How do you think ? Cause it pretty annoying me... only few minutes at one website and my phone is hot like an oven....
Uliwooly
check the battery temperature
Domenic
Visitor
I tested and the result is next:
1. 25 c° - after unlocking the phone/ apps closed / brightness 35%
2. 28.3-28.9 c° - while using menu few minutes / apps closed / brightness 35%
3. 29.7 c° - screen ON + Wifi ON / apps cloes / brightness 35%
** 10 minutes passed 3% of battery used
4. 32-32.9 c° - web serfing for 10 min. / chrome opened / brightness 35%
7% of battery used after 20 minutes
5.  33.3-38.2 c° - played some game (Jelly Defense) for 10 minutes  / brightness 35%
14% of battery used after 30 minutes in total
6. 40.4 c° - played the same game but 80% brightness fot 7 minutes
22% of battery used after 37 minutes in total
so is it normal ?? o_O at 40.4 it was pretty Hot... and at chrome it was warmy..
Uliwooly
that's normal, also check this
settings > accounts & sync > tap on each and check what's syncing, it could be facebook or google plus or google uploading all your pictures.
Domenic
Visitor
I'm not using facebook at all, only gmail and thats all..Set up in google syncing only chrom and gmail... will see if it helps...
