Sound notification messages
SOLVED
kesleydeoliveir
Visitor
My Xperia U is not playing sound notification messages. The sound settings enabled the sound to messages and notifications and configuration of message is also to play sound when new messages, most will not play anything. The Smarth the only one vibrated and nothing else, what can this be?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
which messaging app are you using? or on which app you are not getting notifications?/
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
3 REPLIES 3
Uliwooly
kesleydeoliveir
Visitor
You can leave after both the xperia tweak could fix. Thank you for your attention.
:smileygrin:
Uliwooly
did you figure it out?
