Text Message Verification.
Nicht anwendbar
Hi everyone,
Does anyone know how to get the text messages to show whether the sent text message hs been read? Prior to the 2.3.3 Android update, I had this feature where the text would have a white check mark to the right of the text, however I lost this feature as soon as I updated Android. Does anyone know how to get it back, or a way to get it back?
Thanks.
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Sam
Legende
Legende
It sounds like you are referring to Delivery Report:
Main Menu > Messaging > Menu Button > Settings > Tick the Delivery Report option.
However be aware this will show that it has been sent and hit the network server, it will not tell you if it has been read as there is no way for your handset to know.
5 ANTWORTEN 5
Sam
Legende
Legende
Nicht anwendbar
Thanks so much!
Sam
Legende
Legende
No problem, glad that helped Slightly_smiling_Face
Nicht anwendbar
If you would like to try a free third party SMS app, it has a lot of other features that the default sms app does not have.
If interested, have a look at the following app free apps :
Go SMS Pro
https://market.android.com/details?id=com.jb.gosms&feature=search_result
Handcent SMS
https://market.android.com/details?id=com.handcent.nextsms&feature=search_result
Nicht anwendbar
you should also note that your network supplier may charge you for this service
