Hi--
When i'm trying to update Xperia neo v firmware there is a message from step two that informs me Sony update engine could not be installed (error 0x0803d0020), what can I do?
Gelöst! Gehe zu Lösung.
I tried it on another system and was able to get the update done successfully.
Thanks all for the support.
Hi there.
Some computers may block the installation of the update service, Please use this:
http://www.sonymobile.com/us/tools/update-service/ this is the Standalone update software.
It should work better with your computer configuration.
Have a good day.
Francis
Hi --
Will Using Update Service erase the phone data like (contacts, messages, settings etc.,)? because doing an update through the pc companion does not erase any contents.
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
anytime
