When my Xperia Neo V is restarted...
SOLVED
FatsGordon
Visitor
...it loses the animated wallpaper I've chose (Earth turning as seen from space). This happens each and every time I restart it.
How can I get the phone to keep the animated wallpaper when restarting?
Thank you!
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you can read about how to sideload apps here
http://talk.sonymobile.com/thread/36355
if you moved this app/wallpaper to the SD card then that's the problem
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
11 REPLIES 11
Uliwooly
there might be an app stopping this, perhaps a taskiller or antivirus
FatsGordon
Visitor
Thank you, I have both, I'll try first uninstalling the task killer and if it does not work I'll will ask you again about the antivirus, just to make sure I'm not doing something wrong.
Uliwooly
you don't need antivirus apps, you can also repair your phone with either SUS or PCC
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Alternatives on How to backup Xperias
FatsGordon
Visitor
Thank you uliwooly!
Uliwooly
let us know how it goes
FatsGordon
Visitor
Mmmm... I did uninstall the task killer AND the anti virus, restarted the phone and the animated wallpaper was gone... replaced by the default theme wallpaper (it resembles me an Star Trek announcement, BTW).
What else could be avoiding it to start up?
Uliwooly
it could be that the phone ran out of RAM and that stops the live wallpaper, did you sideload this wallpaper? do you have any RAM or Battery apps?
FatsGordon
Visitor
How do I sideload the wallpaper? Please explain to me.
As far as I know I don't have any battery or RAM apps. Just a battery meter and APP2SD. Could any of them be provoking this behavior?
El mensaje fue editado por: FatsGordon
Uliwooly
