Xperia T cellular problems
SOLVED
ilian_tomov
Visitor
Happy Holidays! Sorry to bother you, but I am exeriencing a bit frustrating kind of trouble with my new device. So here it is. When I power on my phone everything works just fine, untill after some time, maybe 15-20 minutes or so, I stop receiving calls, sms, etc. I can't dial a single number and when I dial my number from another phone the signal is "The subscriber's telephone is not switched on or it's outside networks coverage" - same thing as if my phone was off. I tried factory reset, tried to enable Data Rate, enable and disable Plane mode, but still no luck. After some time, without any signs - my bars are full just the cellular module stops working. Could it be from that I changed location ?  Called my operator's helpdesk, they advised me to backup my data, do a factory reset, and if that does not help to visit servie center. And after the software reset, the situation was fine for a whole day or so. And then again, instantly I wanted to dial cust. support number and the message was "We are experiencing technical difficulties, please call again later". When I dial that same number from my other phone (same operator) it connects to cust. support. Please, help. Thank you, in advance.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
the lower the number -105dBm the worse the signal is. it seems that you have a really bad coverage area and that might be the issue
7 REPLIES 7
Uliwooly
get a new SIM card also do you have any
taskillers
antivirus
battery apps
ram apps
boost apps?
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
ilian_tomov
Visitor
Thanks, uliwooly for the fast response. About getting a new SIM card, the truth is that my current one is quite new, I have signed a new 2 year contract with the carrier and they gave me micro SIM, I put it in the phone and the activated it the next day. Could it be factory malfunction with the SIM itself ?   As for the apps, nothing but the original preinstalled apps, except for facebook, skype, box, dropbox and autocad WS.
ilian_tomov
Visitor
PS. I also noted that the signal bars are changing quite often and here i have just one.... sometimes none and maximum of two.... And then the meter goes full and the problems start - no voice calls, sms, mms, etc.
Uliwooly
oh ok, so the problem then it's poor network coverage, go to settings > about phone > status > signal strenght
ilian_tomov
Visitor
The signal strength with 1 bar is: -105 dBm 5 asu
Now: 2 Bars   -99 dBm 7 asu    don't really know wha tthat means
And still the problem appears often when the meter has full bars...
Uliwooly
ilian_tomov
Visitor
Didn't have problems since my last post so far. Hope that the poor coverage was the reason. Will keep you informed.
