Bug with number pad in call phones menu
SOLVED
imposeren
Visitor
My phone displays both number keyboard and contacts behind it. Here is screenshot:
Any way to fix it?
model: ST21i
build : 11.0.A.0.16
1 ACCEPTED SOLUTION
Accepted Solutions
Johan
Master
I have never seen this before. I suggest that you try to reboot the phone and check if it remains. If yes try to reinstall the phone software using SUS. That should fix the problem.
http://www.sonymobile.com/gb/tools/update-service/
2 REPLIES 2
Johan
Master
imposeren
Visitor
Installd fresh update and that solved my issue
