Xperia T Indicator Lights
SOLVED
andyseefromull
Visitor
Is there an option to have an indicator light flashing when the phone is on standby whenever I receive a text message or missed call. This is a very useful function on both my previous Nokia and Blackberry phone, but so far all I have been able to get is an audible indicator as the action is received. Anyone able to help?
1 ACCEPTED SOLUTION
Accepted Solutions
miffy
Contributor
There's no option on the phone,
but install this from Play Store.
Works great
https://play.google.com/store/apps/details?id=com.tomatox.missedmessageflasher
You can adjust flashing screen, sound or vibration.
Even how often and duration.
3 REPLIES 3
miffy
Contributor
Works great
andyseefromull
Visitor
thanks. i will try to install now
miffy
Contributor
It wont work fully if you have Extended Battery Mode turned on,
but that doesn't seem to save much battery anyway.
