- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
November 2010
November 2010
Audio Description
My Sony Bravia has recently started to add Audio Description to several programmes on various channels. I don't want it. How do I stop it?
Solved! Go to Solution.
36 REPLIES 36
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2018
September 2018
I just kept trying and then left the TV off for a while (15 mins?) then turned it on and tried again and eventually it worked.
Its ages ago now so I can't recall exactly how may times I tried but I wrote this at the time:
Hi, maybe try again and wait a while before turning the settings back on and then wait a while again to see if it takes effect?
AUTO SERVICE UPDATE - this should be on, CHANGE IT TO OFF, then underneath it, go to:
SOFTWARE DOWLOAD - this should also be on, CHANGE IT TO OFF, then go back to watchin TV for 10 minites
Then turn them both back to ON and wait again...
Hope it works for you......good luck with it!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2019
January 2019
auto description is set to “off” but still is functioning
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2019
September 2019
I have a KD-65XD8599 running Kernal version 3.10.70. Please help me turn off the extremely irritating narrations (Audio Description) on certain programs. I can't seem to find it in the settings.
Thank you and kind regards
Jason Budge
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
December 2019
December 2019
I have recently found a blind and deaf service added to my KDL20S2020 tv
how do I remove?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
December 2019
December 2019
There's a button on the remote.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
April 2020
April 2020
I can't turn off audio description although it is already set to OFF! HELP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
April 2020
April 2020
This fix didn't stop audio description. Any other ideas?
- « Previous
- Next »
