KDL37W5500 Optical Audio and Update
sjjhr67
New
Dear all, I have an old but perfectly working KDL37, and a number of questions:
1: how do I set it so it defaults to HDMI2 at start up? It gets confused whether my Virgin box is turned on or not
2: when testing the internet connection, it switches off automatically so I can't tell if it's connected
3: can I updated it via the internet?
4: optical audio out doesn't seem to work when powering a Devialet Dialog and 2 phantom speakers
Any answers gratefully accepted thank you
1 REPLY 1
EdwinaU
Moderator
Hi,
Welcome to the community.
You'll find the manuals and help guide for your TV here. That should hopefully help with your questions.
Best wishes,
EdwinaU
