- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
No picture & very loud volume
Our Bravia KDL37V5810 has suddenly lost its picture but still has a very loud volume. It is not responding to the hand set. Can anyone help please.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
this is not an easy one to answer sitting here but may i suggest trying to change channels on the set itself, if things are still the same it certainly sounds like a tuner fault and will need a visit to a Sony repair centre if its still under warranty.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
Many thanks. It will not respond to handset or the switches on the set so I think it is a triip to the repairers.
Its warrenty ended May 1st.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have exactly the same problem! The set seems to go into "standby" when switched on, but won't respond to either the remote or the on-set controls.
It "pops" every 10 minutes or so, and after several of these the volume comes on, but at a deafening level.
My only solution so far is to unplug it.
It's two years old tomorrow!
Message was edited by: icba1957
