- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
January 2013
January 2013
Sony Bravia KDL-20S2030 - removing plug cable
I have just moved into a new home and want to disconnect the plug cable from the TV in order to feed the cable through the hole in the top of a cupboard down to the plug socket. However the plug is moulded on and the cable doesn't seem to attach easily from the TV end.
Any ideas?
Many thanks, Cath
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2013
January 2013
Hi,
well theres only really 2 options here, one chop off the plug and fit a new one or two use a short extension lead and remove the plug from that, at least that way you dont chop up the original lead.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2013
January 2013
Thanks - I feared that was the answer!
