USB port location on KDL32EX43BU
SOLVED
profile.country.en_GB.title
alshack50
Visitor
Hello, I have just bought this TV and the wirless dongle to go with it.  I never actually saw the TV, just went off reviews, and I'm going to have it wall mounted.  I then realised that if I have it mounted, the USB stick might not fit and I was wondering if anyone had this TV and could let me know where the port is, and indeed if it would be a problem mounted.
Thanks
Alex
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi Alex,
welcome to Questions & Answers..:smileyhappy:
According to the KDL32EX43B specifications there is one USB connection which is stated as being located on the side of the TV, therefore it shouldn't cause a problem if your fix your Bravia to the wall..
2 REPLIES 2
Thalamus.
Champion
Hi Alex,
alshack50
Visitor
Thanks for that info, I had tried looking for something like that, and even when I typed in the product number in the searches button on the Sony website, came the very helpful reply - product not found!
Thanks again!
