annulla
Cerca invece
Intendevi dire:
CPU for VAIO RX2D
gbrodkorb
Visitatore
CPU for VAIO RX2D
Hi,
I have a VAIO RX2D and my CPU is defect. Now I'm looking for a replacement, but I connot find a CPU with 1.7 GHz anymore. Anybody knows if the installed motherboard (ASUS P4B266-LM) can work with other CPU than Pentium 4 1.7GHz? If yes, which are possible.
Thanks for your help,
GB
5 RISPOSTE 5
paddy_uk
Visitatore
Here's a link to the manual for your motherboard:
http://www.asus.com.tw/support/download/item.aspx?ModelName=P4B266
gbrodkorb
Visitatore
Thank you for your answer, but i'm not sure if P4B266 is the same as P4B266-LM
I will try to find a CPU described on that web page.
GB
paddy_uk
Visitatore
This is the MoBo product page for ASUS UK. They list the M, C, E & SE versions of the board but no mention of LM. Must be just M.
http://uk.asus.com/products/mb/overview_p4.htm
Regardless, they all list CPU supported range from 1.4 GHz to 2.4GHz+, so I would safely say that you can stick in 2.4GHz if you wanted.
paddy_uk
Visitatore
Just found this & it may make you an unhappy chappy!
http://www.driverforum.com/bios4/6479.html
Basically the board was made specially for Sony & Sony are the ones doing the updating. In that case you should check out your options via Vaio-Link :
http://www.vaio-link.com
You will need to register your rig & will then beable to access manuals, updates & the likes for your system. Once registered, just click on enter as vaio user.
gbrodkorb
Visitatore
Thank you for your help
GB
