dpp-fp30 printing problem
profile.country.en_GB.title
DavidG100
Visitor
My printer only prints out less than half the photo, the rest is blank.
I have changed the cartridge thinking that this was the problem but no.
Has anyone had the same problem and found a solution?
Thanks.
4 REPLIES 4
Blencogo
Are you printing direct from a PictBridge capable camera using USB or are you printing from a PC using the supplied PictureGear software?
Has the printer worked properly in the past using the same Camera/PC?
What size paper are you using?
Here is a copy of the Manual: -
http://pdf.crse.com/manuals/2190186121.pdf
:thinking:
MetjeD
New
My DDP-FP70 printer only prints less than half of the picture, the bottom part. I changed the cartdridge and paper and it still doesn't work. I only used it twice: the first time I printed out from a memory stick 2 photos perfectly.Now I tried again with a memory stick and it only prints the bottom part of the photo. Can you help me fix it? Thanks.
BettyW1
New
Thanks.
wcndave
New
2019 and I am also having this problem.  Did anyone ever get it resolved?
