TV SideView / Vaio Remote Control for VGP-URM10
cohprog
Hello,
I have an USB infra-red adapter (VGP-URM10) for my Vaio Flip. I am supposed to install 2 applications to be able to use it : TV SideView and Vaio Remote Control. But I don't know where to download them from. I can't find them in Windows Store and I can't find a download area on Sony website.
Any idee where to download those software from ?
Cheers!
6 ANTWORTEN 6
Nobody-in-particular
Vielschreiber
Hi, it does state that both of these applications should be available to download from the Windows Store but oddly I am ony able to locate TV Sideview application but the links on TV Sideview official site look like a good place to start.
Blencogo
Hi cohprog and welcome.
I think the IR Remore Control update is available from the support page for your model.  Unfortunately, you do not give us your exact Vaio model so I cant give a link but here is the generic driver update dated 18 March 2014: -
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/preinstalled_drivers_win8_9482/SVF15N2C5E
Is this the TV SideView app you need?
http://apps.microsoft.com/windows/en-gb/app/tv-sideview/9dd58d3f-bbc5-4185-82fb-e23cc84782ef
This guide from the Sony US website may be a help: -
http://helpguide.sony.net/lifestyle/en/view/
:thinking:
Vielschreiber
Cohprog has a custom built Flip 13A if that helps you in any way Blencogo!
cohprog
I have a "SVF13N2C5E" and there is 0 driver / software listed on the website. I checked some other similar models (SVF13N1C5E and SVF13N2M2E) that I have access to : they have some drivers/sofwares listed but nothing for that USB dongle.
Anyway, I think that the drivers are ok : when I connect the dongle, its detected and listed in the devices as "Sony IR Remote Control". It's the applications to use it that I am looking for.
I can't find the SideView software on Windows Store. And if I try to download it from the link listed above, it says that this application is not available for my device.
I checked with a similar Flip 13 (SVF13N2M2E) that wasn't custom built and so didn't had a "clean install" : It has the TV SideView application pre-installed. But I can't find it either from the Windows Store and the link on the website give me the same error : Not available for your device.
There is a second application "Vaio Remote Control" that let you use the computer as a infrared remote control for your TV or other. I couldn't find this application anywhere either and it's not pre-installed on the other Flip 13 I checked. I found some reference to it on Google but the pages, from the Sony website, listed don't exist anymore...
Hugo_Fonseca
Hi all!
Let's bring back from the dead this post.
So it is 2023, I still use a Vaio, have the Vaio IR adapter, everything was fine, except some weeks ago I had to reeinstall windows and now the apps are no longer avaiable.
If anyone sees this, do you know a place where I can still download them, the TV Guide for Vaio and the Vaio IR remote app?
Thank you so much.
HannahEd01
Community Team
Hi Hugo_Fonseca, unfortunately, Sony sold the brand a very long time ago, so they no longer provide any software for it. But good luck.
