- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
if my iPhone si wired to MEX-BT3900U, can I use navigation app in my iPhone?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Delca85,
After read the whole manual (:smileyhappy:), I was not able to found any comment telling me the opposite. So... to be clear... Yes, you can use the iPhone Navigation app with MEX-BT3900U connected by Bluetooth, even on the Passenger mode (Pag. 20).
Note : Please, read the manual first !
To operate the iphone, you need to consider all details about the compatibility with iPod, see “About iPod” on page 33 or visit the support site. In these Operating Instructions, “iPod” is used as a general reference for the iPod functions on the iPod and iPhone, unless otherwise specified by the text or illustrations.
Go Ahead and Test. Keep us informed, Ok ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Welcome to ClubVaio,
Yes. The MEX-BT3900U works perfectly with iPhone / iPod equipment. Easy to read display, and removable faceplate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok, but if I am listening the music in my iPhone by the MEX-BT3900U, can I use navigation app in my iPhone?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That's the idea behind the product. :smileyhappy:.
Finally, Navigation commands will go through Bluetooth streaming too. If you're playing a song, the song won't pause, but the song will mute, and you'll hear the Navigation voice prompt. Once the Navigation voice prompt finishes, the song will resume.
It's highly recommend to buy an external microphone to assure clarity of your phone calls.
I am adding a specific MEX-BT3900U link 4U with :
- General Info
- User manual
- Repair Info
- Sony support contact
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok, thank you very much.
I have looked for the information I need, but I haven't been able to find it in your link. I would like to understand if I can use iPhone app when iPhone is connected to the radio, even if is in passenger mode.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Delca85,
