Walkman NWZ-W252 wont charge anymore
profile.country.hr_HR.title
usernameless
Visitor
I cant charge my walkman anymore. When I plug it into my computer nothing happens like i never plugged it in in the first place. If I start the content transfer it asks me to connect my device. Never had any problems before. My battery went out the other day and i connected it to my comp and this is the first time this happened. I tried to reset already. Any advices???
1 REPLY 1
profile.country.mk_MK.title
ChrisCanon
Visitor
did you try to move arround your cable to make sure that the connection is good or check with other devices that your USB port is good?
happend to me on my phone... i just cleaned the pins with a wooden toothpick... but be carefull
