Solved! Go to Solution.
Still I would try resetting the Network Settings, first. It only takes a couple of minutes, you'll just have to register the BT device and log into your WiFi APs again. The settings aren't just the WiFi/BT connections, some files get created in /data. And those, since it stops to work, may be corrupted.
I'm very sorry to hear that
Would it be possible for you to take a log from your phone and send this to me? I'll forward it internally for investigation.
To do this:
Settings > About phone > Build number, tap 7 times on the build number
Go back to Settings and select Developer options and turn on "USB debugging". Then tap "Logger buffer sizes" and set this to "4 M".
- The next time you notice that bluetooth has turned off and can't be turned on:
Settings > Developer options, select "Take bug report". When the report is ready (may take a minute or so) you get a notification that you can tap and share to Google Drive. Please send me a link to this file in a private message.
Rickard , I will send you the logfile after I will try all the work arrounds the other users suggested, I hope they will fix my problem.
Anyone else with the same problem with Xperia X compact F5321 ?
I have now the 34.1.A.3.22 firmware , everything works without any problems on my phone, wifi, screen, camera, speed , battery, the only issue is with the low brightness in dark places but I don't mind so much, and the speaker volume comparing to the z5 compact is lower and not so good like z5c.
Yes the same case for me, with my previous Z5c everything was great bluetooth was working great.
What firmware do you have on your X compact now ?
