Deel jouw ervaring!
Hi;
Sony sbh80 battery status doesn't show on X but it was fine with Z3 compact
Opgelost! Ga naar oplossing.
@nuked Smart connect shows it as far as I know.
Bekijk de oplossing in de community in het oorspronkelijke bericht
you're right i installed smart connect than battery status finally pop up
Cool.
