I just got a Z3 compact. I switched from a Moto X that did not have any bluetooth issues (which is still in my possession in case I can't fix this).
Anyway, when I connect to my Pioneer MVH-X560BT stereo, music will play but the audio will drop out completely every few minutes. The audio will go out for around a second. It's not lag because the song doesn't also pause when the bluetooth audio drops. After a second audio will return. I have tried many apps (Walkman, Power amp, google play, spotify, etc.) and they all produce the same occasional pause. I have used a few different phones with this stereo and have never experienced this issue.
I bought my Z3c online from someone who had unlocked the bootloader and installed a custom ROM. I found out how to install the stock Sony rom with Emma and thought that would fix my bluetooth issues. It did not. I doubt an unlocked bootloader would affect bluetooth.
I have just tried my Z3 with a different bluetooth speaker and it works without skipping.
Both my old phone (Samsung) and the Pioneer stereo are bluetooth 3.0; they worked flawlessly together.
Therrefore it now seems to me that the z3 must have a backwards compatibility issue with bluetooth 3.0
Edit: I was unable to overcome the compatibility problem with Sony Z3 compact plus pioneer stereo. I therefore sold the stereo and replaced it with a Kenwood BT53U, which works flawlessly.
Same issue here with a brand new Z5 compact and the Pioneer DEH-X5600BT. Old HTC one m7 worked Great but this?.. It Will be with tears in my eyes I need to go back and run aux cable because Sony cant fix this.. The Bluetooth mic I had to mount down half the car to install looks dumb now..
Greetings from Ukraine!
Same issue here.
Xperia Z5 Compact (running Android 6.0) plus Pioneer MVH-x560BT. Sometimes it takes mercy upon me, allowing me to listen for a song or two without dropouts. But mostly there's a second of silence every two minutes or so, which keeps driving me crazy.
Switching off Wi-Fi doesn't help.
Both Lumia 525 (which is probably the cheapest smartphone out there) and Nexus 7 Tablet perform flawlessly.
Not quite sure now, what was all the fuss about Sony's superior software and audio quality :(.
n5100bt user now, with the z3 compact. the bluetooth problem is solved. but not everything is perfect. 3 times in one month, the sony mex n5100bt froze . i had to reset the thing, loosing all my presets. the cause was a flac tune on my highspeed usb dongle. so, sony mex n5100bt might be a flac player, but not a perfect one. a good one, but not perfect. would i buy again the z3 c? yes i would. would i buy the n5100bt? yes i would, unfortunately, yes. so , if you have questions about the 5100bt, ill answer them.
Hello,
I have the same problem with my XPeria z3 compact since I upgraded to Android 6.
It randomly disconnects from whatever audio bluetooh receiver it is connected to (reproduced on Volkswagen car audio, Sony DR-BTN200 headphones, avantree saturn apt-x receiver, UE Boom 2 speakers). I have tried to debug the issue, and here is what I found.
I have collected the logcats during the disconnection and I discovered that just before each time the bluetooth disconnects there are two lines concerning "BeaconParser" I think this has to do bluetooth LE. Here is an extract from the logcat:
09-07 15:48:56.769 26741 26823 V Avrcp : MESSAGE_PLAY_INTERVAL_TIMEOUT 09-07 15:48:56.769 26741 26823 V Avrcp : event for device address 88:C6:26:81:22:9E 09-07 15:48:56.769 26741 26823 I Avrcp : device found at index 0 09-07 15:48:56.769 26741 26823 V Avrcp : event for device address 88:C6:26:81:22:9E 09-07 15:48:56.769 26741 26823 I Avrcp : device found at index 0 09-07 15:48:56.769 26741 26823 V Avrcp : getPlayPosition position: 10197 Device:88:C6:26:81:22:9E 09-07 15:48:56.769 26741 26823 I BluetoothAvrcpServiceJni: registerNotificationRspPlayPosNative: sBluetoothMultiAvrcpInterface: 0xb34d1630 09-07 15:48:56.769 26741 26823 D bt_btif : ## register_notification_rsp ## event_id:AVRC_EVT_PLAY_POS_CHANGED 09-07 15:48:56.769 26741 26795 D bt_btif : LCB lcb=1 event=2 state=2 09-07 15:48:56.788 26741 26777 W bt_hci_packet_fragmenter: reassemble_and_dispatch complete l2cap packet received:l2cap full length 18 and hci length 26. 09-07 15:48:56.788 26741 26795 D bt_btif : LCB lcb=1 event=6 state=2 09-07 15:48:56.788 26741 26795 D bt_btif : bta_av_rc_msg_cback handle: 0 opcode=0x0 09-07 15:48:56.788 26741 26771 D bt_btif : btif_av_state_started_handler event:BTA_AV_META_MSG_EVT flags 0 index =0 09-07 15:48:56.788 26741 26771 D bt_btif : btif_rc_handler event:BTA_AV_META_MSG_EVT 09-07 15:48:56.788 26741 26771 D bt_btif : AVRC_ParsCommand() return status:0x4 09-07 15:48:56.788 26741 26771 D bt_btif : btif_rc_upstreams_evt pdu: AVRC_PDU_REGISTER_NOTIFICATION handle: 0x0 ctype:3 label:e 09-07 15:48:56.788 26741 26771 I BluetoothAvrcpServiceJni: btavrcp_register_notification_callback 09-07 15:48:56.788 26741 26823 V Avrcp : MESSAGE_REGISTER_NOTIFICATION:event=5 param=1 09-07 15:48:56.788 26741 26823 I Avrcp : device found at index 0 09-07 15:48:56.788 26741 26823 V Avrcp : processRegisterNotification: eventId5 09-07 15:48:56.788 26741 26823 I Avrcp : device found at index 0 09-07 15:48:56.788 26741 26823 V Avrcp : getPlayPosition position: 10216 Device:88:C6:26:81:22:9E 09-07 15:48:56.788 26741 26823 I Avrcp : device found at index 0 09-07 15:48:56.788 26741 26823 V Avrcp : getPlayPosition position: 10216 Device:88:C6:26:81:22:9E 09-07 15:48:56.788 26741 26823 I BluetoothAvrcpServiceJni: registerNotificationRspPlayPosNative: sBluetoothMultiAvrcpInterface: 0xb34d1630 09-07 15:48:56.788 26741 26823 D bt_btif : ## register_notification_rsp ## event_id:AVRC_EVT_PLAY_POS_CHANGED 09-07 15:48:56.789 26741 26795 D bt_btif : LCB lcb=1 event=2 state=2 09-07 15:48:56.789 26741 26823 V Avrcp : mPlayPosChangedNT updated for index 0 index 0 09-07 15:48:56.839 29688 29688 I CrashlyticsCore: Initializing Crashlytics 2.3.8.97 09-07 15:48:56.882 29688 29688 D BeaconParser: Parsing beacon layout: m:2-3=beac,i:4-19,i:20-21,i:22-23,p:24-24,d:25-25 09-07 15:48:56.883 29688 29688 D BeaconParser: Parsing beacon layout: m:2-3=0215,i:4-19,i:20-21,i:22-23,p:24-24,d:25-25 09-07 15:48:56.887 1937 2164 D BluetoothManagerService: Message: 20 09-07 15:48:56.887 1937 2164 D BluetoothManagerService: Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@fd915d5:true 09-07 15:48:56.888 1937 4961 D BluetoothManagerService: checkIfCallerIsForegroundUser: valid=true callingUser=0 parentUser=-10000 foregroundUser=0 09-07 15:48:56.888 1937 4961 D BluetoothManagerService: disable(): mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@bd361ea mBinding = false 09-07 15:48:56.889 1937 2164 D BluetoothManagerService: Message: 2 09-07 15:48:56.890 1937 2164 D BluetoothManagerService: Sending off request. 09-07 15:48:56.890 26741 26767 D BluetoothAdapterState: Current state: ON, message: 23 09-07 15:48:56.890 26741 26767 D BluetoothAdapterProperties: Setting state to 13 09-07 15:48:56.890 26741 26767 I BluetoothAdapterState: Bluetooth adapter state changed: 12-> 13 09-07 15:48:56.891 26741 26767 D BluetoothAdapterProperties: onBluetoothDisable() 09-07 15:48:56.891 26741 26767 I BluetoothAdapterState: Entering PendingCommandState 09-07 15:48:56.892 1937 2164 D BluetoothManagerService: Message: 60 09-07 15:48:56.892 1937 2164 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 12, newState=13 09-07 15:48:56.892 1937 2164 D BluetoothManagerService: BLE State Change Intent: 12 -> 13 09-07 15:48:56.894 1951 1951 I ActivityManager: type=1400 audit(0.0:16740): avc: denied { call } for scontext=u:r:system_server:s0 tcontext=u:r:zygote:s0 tclass=binder permissive=1 ppid=701 pcomm="main" tgid=1937 tgcomm="system_server" 09-07 15:48:56.898 26741 26741 D BluetoothMapService: onReceive 09-07 15:48:56.898 26741 26741 D BluetoothMapService: onReceive: android.bluetooth.adapter.action.STATE_CHANGED 09-07 15:48:56.898 26741 26741 D BluetoothMapService: STATE_TURNING_OFF 09-07 15:48:56.898 26741 26741 E BluetoothMapService: mSessionStatusHandler.sendMessage() dispatched shutdown message 09-07 15:48:56.898 26741 26741 D BtOppService: Receiver BLUETOOTH_STATE_CHANGED_ACTION, STATE_TURNING_OFF
here is another:
09-07 15:33:49.057 26524 26524 D BeaconParser: Parsing beacon layout: m:2-3=beac,i:4-19,i:20-21,i:22-23,p:24-24,d:25-25 09-07 15:33:49.058 26524 26524 D BeaconParser: Parsing beacon layout: m:2-3=0215,i:4-19,i:20-21,i:22-23,p:24-24,d:25-25 09-07 15:33:49.062 1937 2164 D BluetoothManagerService: Message: 20 09-07 15:33:49.062 1937 2164 D BluetoothManagerService: Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@74f4ccd:true 09-07 15:33:49.063 1937 5184 D BluetoothManagerService: checkIfCallerIsForegroundUser: valid=true callingUser=0 parentUser=-10000 foregroundUser=0 09-07 15:33:49.063 1937 5184 D BluetoothManagerService: disable(): mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@9b85982 mBinding = false 09-07 15:33:49.066 1937 2164 D BluetoothManagerService: Message: 2 09-07 15:33:49.068 1937 2164 D BluetoothManagerService: Sending off request. 09-07 15:33:49.068 21956 21983 D BluetoothAdapterState: Current state: ON, message: 23 09-07 15:33:49.068 21956 21983 D BluetoothAdapterProperties: Setting state to 13 09-07 15:33:49.068 21956 21983 I BluetoothAdapterState: Bluetooth adapter state changed: 12-> 13 09-07 15:33:49.069 1937 2164 D BluetoothManagerService: Message: 60 09-07 15:33:49.069 1937 2164 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 12, newState=13 09-07 15:33:49.069 1937 2164 D BluetoothManagerService: BLE State Change Intent: 12 -> 13 09-07 15:33:49.074 21956 21956 D BluetoothMapService: onReceive 09-07 15:33:49.074 21956 21956 D BluetoothMapService: onReceive: android.bluetooth.adapter.action.STATE_CHANGED 09-07 15:33:49.075 21956 21956 D BluetoothMapService: STATE_TURNING_OFF 09-07 15:33:49.075 21956 21956 E BluetoothMapService: mSessionStatusHandler.sendMessage() dispatched shutdown message 09-07 15:33:49.075 21956 21956 D BtOppService: Receiver BLUETOOTH_STATE_CHANGED_ACTION, STATE_TURNING_OFF
each we see lines like this just prior to the disconnection:
I hope this will help Sony fix the issue.
hi
same problem here, still no solution !
I have experienced exact same audio drop out problems with Sony Xperia L1 and Pioneer MVH-X560BT. However my Pioneer works flawlessly with Samsung Galaxy and even with Lumia 640 XL.
I have similar compatibility problems with other Sony products as well and I have gave up until now. It's better to avoid Sony if just possible, since they do not give about sh*t about customer experience. This audio drop out problem will propably get never fixed. I have HDMI audio problems with all SONY TV's and one of the models with problematic behavior is very ancient (KDL-40W3000). All the displays works theoretically, but i get invasive OSD messages regularly when audio stops and starts again like in the link below.
https://www.youtube.com/watch?v=1ysMZWlrmx8&t=5s
Very annoying like this bluetooth sreaming issue with Xperia L1.
I have the same problem with my XZ when connectwed to my car's phone hook up.
