Mache meiner kontakt werden nicht durchgedtellt und laden auf der mailbox anderen kommen durch wie kann ich das ändern
Make my contact are not durchgedtellt and load on the mailbox other come through how can I change that - GT
Hi @Olli4444444, let me see if I can help out here!
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
I am not really sure on what you mean by your question, is it possible for you to elaborate a bit?
Please do elaborate and I will do my best to assist you!
I am not availabel for anybody but I can give A call to everybody how can I change my settings so that I get availabel again thanks
Thank you @Olli4444444 for the clarification!
Have you checked if the Do Not Disturb-mode is on? Do not disturb is a mode that mutes some or all notifications depending on how it is set up. To check this, Drag the status bar downwards, then tap Do not disturb-icon.
Another thing that you can try is to reboot your phone in safe mode to see if this behaviour persist there. All apps downloaded from Play Store is temporarily deactivated while in safe mode and by doing this, you can see if this behaviour is caused by a downloaded app. For more information on safe mode and how to use it, click here.
Try these measures and feel free to keep me posted with the results!
