camera button not working properly
SOLVED
traviz
Visitor
Hi everyone,
I've bought my Xperia Z2 few days ago and have strange issue - my camera button doesn't work in every mode. I can open camera app by holding button but can't take any picture in auto mode. Button works in 4K video, Timeshift video, AR effects, Timeshift burst mode. I didn't check Vine, info-eye and social live modes only. I can take pictures by touching the screen button in every mode. Do you have any ideas how to resolve this problem?
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
hedrox87
Contributor
It is a two step button, first is very light and it works as a camera focus button,but you should feel it clicks in a half way, than you press harder and it takes photo just like a real compact cameras do. If you don't feel any pressing degree it might be faulty, it's just a silicone stripe with plastic buttons so it could be badly installed in factory.
Last time, just to be sure, try to start the phone in service mode (restart and when sony logo appears press volume down till it fully starts and you see grey text on main screen "safe mode" if then it will work - reinstall android with sony companion, and if system repair won't do any changes consult the phone in sony centre or the shop where it was bought.
9 REPLIES 9
hedrox87
Contributor
As it works in other modes than SuperAuto I would suggest to clear cache and Data of the camera App in settings, aplications, ALL.
Other thing you need to test it in manual mode, timeshift burst and videos do not actually use the half-button focus, but react for full press.
Try to clear data nad cache in settings and then restart phone, will see if that will help Winking_Face
traviz
Visitor
Actually I dont't feel difference between half-pressed button and full-pressed, should I? Cleared data gives no result Slightly_frowning_Face
hedrox87
Contributor
19667
Contributor
Try to repair your 4n via PCC
Do not forget to give kudosKudos 2.JPGand to select the correct answer Solution.JPG
traviz
Visitor
OK, so I've tried to use camera button in Safe Mode - no result.
When I press camera button slightly I feel it clicks, but after that, when I press harder then it doesn't clicks - should it be like that?
@kanchuka, what does it mean "4n via PCC" ? Slightly_smiling_Face
traviz
Visitor
I went to the store and test brand new Z2 camera button and it's working a little bit different - in my phone I dont't feel second click Slightly_frowning_Face
milavarela
Visitor
I'm with the same problem. Mine phone is Xperia m dual c 2004. I don't feel the second click as some plp said. Reinstall the android system worked?
XX5
Visitor
Ohh.. It worked! Still the front cam
XX5
Visitor
Yes, firstly, when you press on that cam button, a focus frame adjusts itself on the self (which is in the color of white) when it has focused it becomes blue..then press down harder, you will feel it being pressed 2nd time as well.. and voila!
A picture is captured..
P.S the colors of the frame don't matter much but they can be used to indicate that now is the time to press down harder.
Surely tell if this helps.. hopefully it will.. worked for me, i have Experia C ..
