Clear credentials greyed out and I would like to remove pattern lock... Help please?!
Marchhare
Hey there,
I set a pattern lock on my phone but I would now like to remove it. The clear credentials option is greyed out and I can't select it. I haven't encrypted anything to my knowledge and I don't know where to go from here.
I really appreciate your help.
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
profile.country.RO.title
_alexdon_
There is a small box in the right side of the screen where you can tick/untick access.
alexdon
22 ANTWORTEN 22
_alexdon_
@surtitanuj One thing you can try is to remove guest user.
/t5/Xperia-Z3-Compact/Can-t-remove-the-screen-lock-by-PIN-and-can-t-use-t...
alexdon
Marchhare
Hi there,
Thank you. I can see an option to remove the guest user. I can either switch to the guest or allow phone calls.
_alexdon_
Oh, the account must be removed while you are in guest mode:
/t5/Xperia-Z1-Z1s/Screen-lock-issue-none-option-has-disappeared-entirely/m-p/1068670/highlight/true#...
alexdon
Christofer
Champion
Hi @Marchhare,
Do you happen to have an Exchange Active Sync account in your phone that is related to your work or similar?
If it forces you to use a screen lock it might now allow you to use the normal swipe option or none at all. If that is the case you will have to remove the account from your phone in order to change the screen lock to any of these two options.
Marchhare
I don't think so, how can I find that out?
Marchhare
I entered the guest mode and removed it, the guest still appears as a user when I am in my main user account, and cleat credentials is still greyed out.
_alexdon_
Now check if you can chage the lock type.
alexdon
Marchhare
I can switch between pin, pattern and password. But that's it.
_alexdon_
Christopher asked a good question. Do you have that kind of account?
Read more here:
/t5/FAQ/E-mail-and-Exchange-Active-Sync/m-p/347964#M5
alexdon
