Hi!
I connected my dualshock 4 controller yesterday to the Xperia to try out remote play. And now every time I press the ps4 button on the controller it starts up the xperia and not the ps4. This is a problem for me since I only have one controller.
How can I disable the connection between my DS4 and the Xperia?
Solved! Go to Solution.
Hear is how to do it Bluetooth devices using the Xpdaer to do it. On the ps4 pad push and hold the ps4 button and share button it will flash . Xpdaer go down to the pad push X and X it's
Connect the controller to the ps4 via cable and turn on ps4it will automatically reset controller
