Noise suppression
SOLVED
Renars
Visitor
Noise suppression
Can't finde microphone noise suppression Z5c (was in Z1,Z3, etc.), wery need it. why it is cutted from firmware? Maybe they put it in new one?
1 ACCEPTED SOLUTION
Accepted Solutions
tregate
Visitor
This was answered before in another thread, this option is now ON by default on the Z5 series.
17 REPLIES 17
profile.country.US.title
Qatrium
@Renars
You should find an option called "Mic sensitivity" under Settings -> Sound and notification -> Accessory settings
Renars
Visitor
I now, but its diferent! Nothing common whith noise suppression.
tregate
Visitor
profile.country.RO.title
_alexdon_
It is true, Z5 generation have the option enabled by default.
alexdon
Renars
Visitor
Strange, it dosn't shown in meny, it's always on?! Ok but if its on, then it's not working. Because if i listen music in my car, wired connection (aux) and receive a call voice goes in car speakers, people hear road and engine noise, and echo of themselfs Nothing like that in Z1! I have both phones and can compare! Any proves, Of working noise suppression?
_alexdon_
Renars
Visitor
Thx. For link, i readed it, but there is no any solution. Secondary mic working, i cheked it in servise meny.
Only hope that in new firmware they will fix it.
Now i need to use my old good Z1
Renars
Visitor
Just tested suppression, a lot of calls and can say that its working, but not that way as before, some noise disapear some stay, echo of voise present, some times my voice is cutted. Disapointed......
Not solved, but Moderator can close this thread.
AlexandruRai
Contributor
Recently (a few weeks ago) I had downgraded my Xperia Z5 Compact to 32.0.A.6.200 firmware (very good one) and now (yesterday) I have upgraded by Pc Companion software to Xperia Z5 Compact to 32.2.A.0.253 (wanted camera manual controls).
Now (by latest upgrade) I don't have noise suppression anymore (no standard at all, and no command to activate it). Listen to my recording (xperia M -male voice, good suppression, no ambiental-) and the other one is Z5c upgraded to MM (-female voice, bad suppression, everything is heard-) both in noisy environments. The music is heard from the Z5c environment (room). Here it is: https://vimeo.com/180046894
SO: BAD LENS, NO RAW, NO IMAGE STABILISATION/SOFTNESS AT REQUEST, BAD TEMPERATURE MANAGEMENT, BAD/LOW SOUND/MUSIC QUALITY, NO NOISE SUPPRESSION ON/OFF BUTTON/EFFECT, AND ABOVE EVERYTHING INSANELY EXPENSIVE!!! FOR WHAT AND WHY TO BUY A SONY PRODUCT AGAIN???
SO SONY, DO SOMETHING IN THE NEXT UPDATE PLEASE, IF YOU WANT TO KEEP THE BEST PEOPLE TO YOUR SIDE!!!
Hope I can help!
Thank you for understanding! Rainbow
