Somehow the volume of my Z3C got locked at 0. When I press the volume up button on the side, the slider is displayed but the volume is not increased. When I press the button to show all volume sliders, the Ringtone slider is grayed out, the other two not. Also the slider for Ringtone volume in Setting->Sound and notification is grayed out. So now I need to regularly check if messages have come in and phone calls are probably missed. How to resolve this?
The phone was updated to Android 5.1.1 over the weekend. May be that has something to do with it?
Best regards,
Patrick.
Solution:
This is caused by headphones screwing up volume.
1) Connect headphones (mine was blu-tooth)
2) Play Music
3) Adjust music volume (you will see the slider pop up) Hit the "BELL" symbol - now you can adjust your ringtone volume.
4) Switch back to music volume.. and don't ever change the ringtone volume while listening to music ever again!!!
You might be able to just plug in headphones and adjust it right away, but this worked for me.
Source: Been trying to figure it out for about a week after a workout in the gym, and I accidently changed my ringer volume to zero while trying to adjust my music volume..
Hmm. I had the same problem and fixed it as so:
- Press the volume up key: the volume won't increase but the notification will show
- Drag the volume slider up on the notification. Now you'll have volume!
Software bug perhaps?
VerseChorusCurse's suggestion worked for me.
The fact that it is impossible to change the ring volume when it is set to zero is definitely a software bug in my opinion.
I suspect that I might have set it to zero by mistake when changing the volume of sound on a manual video, even though that would be strange – sound on a video should be a completely different control; anyhow thanks for the suggestion!
It works. By pressing volume up button and then press bell icon.
thank you..
Had the same problem and this solved it !
Hello this worked on my z2, press the volume button, then click on the bell icon that comes up, cycle through and it should be fixed, let me know if it works.
