Solved! Go to Solution.
It might be a little too much. I suggest you to try with a 1.5 A adapter. After watching videos for 40 minutes,it is normal to heat up a little.
If you recently updated,wait some more as it needs some time to settle after a major OS update. See more here:
/t5/Xperia-Z2/Battery-drains-faster-with-Lollipop/m-p/957521#M24272
When you are watching a video, how long is it before it starts to heat up and is the phone just getting warm or is it quite hot to touch?
It is good that it has stabilized. About charging,do you use original sony adapter?
