Sony Xperia Z2 Compact - Where to save a QR code
mogggie
Perhaps you can help as I am elderly and new to smartphones!
I have NHS app on my phone and from tyhis I can bring up a QR code for my wife and my Covid jabs - they appear as two separate QR codes for each of us I know I can download them and get a hard copy from my laptop before we go to the airport and I will do this -  but I can also make them stay on my camera somewhere say in a file or gallery so that I can easily find them to show at the airport?
At the moment when I get mine I the have to lose them and get my wife's - can I store them together?
In simple terms please. Thanks
Moggie
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Uliwooly
@mogggie
Simple solution, take a screenshot of the QR codes > open the album app > open the screenshot > tap on the picture > tap on the empty star at the bottom of the screen > it should turn solid white > it will be a favorite pictures > press back > repeat with the other QR code
both QR codes will be at the top of the album app
screenshot > press and hold power & volume down
or
press and hold power button > menu > screenshot
5 ANTWORTEN 5
Uliwooly
@mogggie
or
Anonymous
Nicht anwendbar
Or if you're using a 3rd party app to scan QR codes, I think the app save the photos, depends on the app
mogggie
Thanks for replying - yes I have found them in Gallery!
Gordon
Anonymous
Nicht anwendbar
That's Great. actually any photo that you receive on your phone, you'll find it in the Gallery of the phone.
mogggie
That worked - thanks so much
Moggie
