Sony Xperia z3 Turned off and will not charge after being submerged for approximately 5 minutes
SOLVED
plyst1
Visitor
As the Subject says. My Xperia Z3 was submerged for about 5 minutes in less than a foot of water. It was charging at first then it began to Vibrate. The pattern goes as such: 1 Vibration (typical to indicate power charging) Then a Triple vibrate. At this point the phone's LED goes off. Now it will restart this process over and over until the phone is unplugged. Whilst submerged the phone's flaps were closed and were not opened. As far as damage is concerned this is a hairline crack in the backglass and part of the Bezel has began to peel away near the camera for unknown reasons. Again this damage is very slight and only someone who knows what the phone looks like new would even see it. Any help would be apperciated.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
I'm sorry to see that, but you have to contact your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
Request a vacuum test.
The crack could be the cause of this water damage.
5 REPLIES 5
Uliwooly
plyst1
Visitor
Then i presume my phone is no longer covered under the warrenty and im out 600 bucks.. WEEEE fun.  There are moments when it DOES start charging which has me hopeful it will eventually dry out and begin operating.
Uliwooly
This looks promising
http://www.reviveaphone.com/
Amethystruby
Visitor
Do not try to charge your phone after water damage, or try to use it at all untill its dry.
place it in uncooked rice for 1-3 days.
Thats what I did and mine works, except for the display, and i think thats because i also tried to turn it on and plug it in after the damage.
good luck
mr_xzibit
Contributor
You may ruined it just by trying to turn it on whilst still wet inside. You should know electricity and water don't mix.
