Streaming Bluetooth audio in car
SOLVED
McVitas
Visitor
Hello, this may be silly question, but I was not able to make my phone use the car speakers. In Bluetooth I have enabled to play audio, but all I could do is make a phone calls through it, but I have no idea how to play music from the phone via car speakers. Point me to some tutorial maybe please...
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
The bluetooth on your car stereo it's only for calls not for music.
9 REPLIES 9
Uliwooly
You might want to check the car manual or car stereo manual
McVitas
Visitor
This does not help much. I am not sure I will find it. Would you rather describe how you play music in the car from your Xperia? Or somebody please Winking_Face When I call, there is a choice in a call screen to choose between audio devices. I don't see such option in a music player. Should it be there?
Uliwooly
@McVitas
Not all cars support this, some cars only support calls but not streaming music.
McVitas
Visitor
I have a removable radio in my car, so actually we should say that radio either supports it or not Winking_Face My phone is paired with it via bluetooth and when I initiate a call from the phone, it automatically shows "dialing..." on the radio display and sound goes through it...
Uliwooly
McVitas
Visitor
I just bought an audio cable with jacks and it's done Slightly_smiling_Face
Uliwooly
@McVitas
Excellent
olraeym56
New
Hi,
I understand the above "only for call, nothing else".
My car is a Volvo V50 of 2010 and I connect my phone via BT.
I use these appes such as Waze or Coyote.
My question is: sometimes when being on a call the sound of those applications can be heard through the speakers. But only then, if I'm not on a call the sound is through the phone only again.
That's what makes me curious, it should technically be possible then?
Thanks
Ollie
