Sudden problem with xperia Z
eadelgado
Just got my sony xperia Z last week. Hardly used it that much. Now out of nowhere it just wont turn on anymore. The Red LED light is flashing whenever I plugged into the charger, but the battery was 50% before breaking down. Any ideas what what the problem is or solution i can take.
Also tried resetting it by presseing both the power button and the volume increase button at the same time. it response with a vibration but still the same.
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Uliwooly
connect your phone to the wall charger > press and hold power & volume up for 8 seconds > let it charge for 1hr > try again.
4 ANTWORTEN 4
Uliwooly
Uliwooly
eadelgado
cheers mate, you saved my ass Lol.
Uliwooly
of course I did, after all
I am AWESOME!!!
