Support for USB Battery Charging 1.2
SOLVED
skylinedreamer
Visitor
Do you guys know if Sony Xperia Z5 supports USB Battery Charging 1.2 (BC 1.2) Specification.
Tags (3)
1 ACCEPTED SOLUTION
Accepted Solutions
Christofer
Champion
@skylinedreamer
I have received information that it does support Battery Charging 1.2.
However, regarding what you are trying to do I am unfortunately unable to assist you.
4 REPLIES 4
Christofer
Champion
Hi @skylinedreamer,
I'm afraid I can't find any specifications for this. I will see if I can find more information.
skylinedreamer
Visitor
Hi Christofer,
I am trying to develop AOA protocol with a USB host driver capable of BC1.2 Spec.
Seems like Z5 is not able to support BC1.2 under CDP mode. It works fine in SDP.
It would be great, if it's able to do so in the future firmware releases.
Regards,
skylinedreamer
Christofer
Champion
@skylinedreamer
skylinedreamer
Visitor
Thank you for the information Christofer Slightly_smiling_Face
