- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, I have issues with tempered glass, I tried 2 kinds of glass and both have the same problem. If I use some application like Facebook or internet where I have to roll page down a long time, the movment is going to lag. Than I must repeat my move even four times until the srceen continues down or up. My moves have the same intensity. And when I change my possition (finger angle) when I´m lying, it´s more worse even ith touches. So I removed glass and it seems good. The problem is odd because my intensity can be different (soft, hard) and it´s working good and about some time it is going to happen. I´m crazy from it. I want to use some protector but don´t foil. Could somebody recommen me what is problem? I used nilikin and vmax. Sorry for my english I hope that you´ll understand me. thank you for help
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Go to settings >about Phone >diagnostics >test> touch screen test then display test and see if there's something abnormal
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tried to put two tempered glass and it worked fine
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How I sad with glass it is bad, without it´s good, i tried to diagnostic, sometimes it found some issues but the digitizer doesnt have any problems places which caused this problem manytimes again and again. Now I dont have any protector and everythink seems to be good. Do you think that digitizer may have some hide defect? I tried even application touch screen, where i set sensitivity
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are they both working good?
Did you find and dark pixels?
Did you find any part in the screen where it lags or not responsive?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
everythink is ok nothing defects pixel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
